Wrong head unit.... HELP!?!?!?!
Old Aug 22, 2010 | 07:29 PM
mustang51js's Avatar
mustang51js
yeah i just saw your thread, all you need to do is undo the allen screws, there is a metal bar that attaches by 2 screws for each, dont pull the sc out but all you need to do after that is rotate the tube to where you need it,actually i think i only removed one screw from each set and loosened the other and then tighten them back up, its very easy to do and even easier if you take the head unit off the car.
Old Aug 22, 2010 | 07:32 PM
bopiela's Avatar
bopiela
^thanks man.
in the position its in, would it be in an ideal spot for an intercooler? i have to do some looking into those tonight. what do you think though??
appreciate the help.
Old Aug 22, 2010 | 07:50 PM
Hangwire's Avatar
Hangwire
Originally Posted by bopiela
^thanks man.
Hush and intercooler it!
Old Aug 22, 2010 | 07:53 PM
bopiela's Avatar
bopiela
^hey now. i was asking if thats where i wanted it pointer for an IC!
Old Aug 22, 2010 | 08:04 PM
Hangwire's Avatar
Hangwire
I see
Old Aug 22, 2010 | 08:24 PM
mustang51js
yes,thats the way i had to turn mine for the intercooler, so what you would do is come straight out of that and go to the drivers side foglight area with a back to back 90 degree elbow into an intercooler(as long as the inlets are at the bottom) then out the other side of the intercooler by the pass fog light and then up to your tb, usually when you do that you need to cut a hole in your inner wheel well to get to the tb because theres to much stuff and the sc would be in the way trying to go around everything, its a decent size hole you need to cut because it comes up at an angle threw it or it would be around a 4inch round hole if you use a bunch of 90's,but then you have more restriction
Old Aug 22, 2010 | 08:28 PM
bopiela's Avatar
bopiela
^thannks!
Old Aug 22, 2010 | 09:18 PM
0949er's Avatar
0949er
hangwire was trying to trick u into buying a intercooler.... what a good trick haha
Old Aug 22, 2010 | 09:49 PM
Hangwire's Avatar
Hangwire
Lol I work for the "intercooler company"! haha
Old Aug 22, 2010 | 09:55 PM
bopiela's Avatar
bopiela
^ just ordered one of 'your' kits.... this thing keeps growin now.. damn, haha.
