Very nice car 0949er! Did you have a clearance problems or rubbing with the Borla Stingers and 315 rear tires? Have you thought about doing Black or Polished Stainless Steel Bumper Insert Letters? I really think that would make the back end stand out a little more.
no, no clearance problems with the rear tires at all. But I have noticed that If I try to make a hard u-turn the front tires rub something... so I have to take those easy and not as sharp
I had those same size tires with those rims and after i just went with a 245 and took the 275s off the rubbing your hearing/feeling is on the lower a-arm i seen it after we pulled the rims off for a tire change. Since i went with a different size tire I dont have that issue anymore but i think after these fronts wear out i will go with a 255 instead of the 245 bc it doesnt look very stretched but it could look better with a tad bit wider tire while avoiding the rubbing
