Firewall adjuster install
So i got my UPR quick click adjuster in yesterday, went over the install sheet and they suck. So I went to MM website and thye have a great install sheet with pics. But I'm confused on the rubber bushing steps. MM says to remove the stock on and install a new smaller one. I don't know if the MM adjuster has a smaller ID than the UPR one.
MM install sheet:
http://www.maximummotorsports.com/co...h/MMCL-3r2.pdf
I'm referring to steps 11 through 15. The UPR sheet does not say anything about a bushing. I don't want to be in the middle of this only to find out I need a bushing AFTER I cut off the "gear puller"-like housing.
I called UPR and he made it seem I cut off the gear puller-like housing and (leaving the stock bushing) install it in the new adjuster...
Anyone remember what they did in regards to this?
THANKS!
MM install sheet:
THANKS!
Beats me, that's what I wanted to know before I get into cutting stuff off my stock adjuster. You need to cut off the gear puller type housing to be able to test fit the new adjuster....but I don't want to be mid-install to find out I need a smaller bushing and then not have a car to go and find one lol
LOL that's not the point. So if I test fit it and I need a smaller bushing, my car is laid up and I can't go get one. I want to have all the parts I need before I cut it off and can't put it back together real quick to get a part...
As far as the quality of the parts...they look great, it's just the install page that sucks and I want a clear answer before I do anything to the car that can't be undone (cutting off the housing).
