power estimate
Old Jan 14, 2011 | 01:22 PM
jstang909's Avatar
jstang909
Default power estimate
so was wondering what kind of power im putting down now. was hoping some of you with the same type of mods could give me some numbers
i have a 98 Gt pi intake and cam swap, CAI, catback exhaust, 75mm Tb and C&L plenum.
i was thinking i would be around 210 rwhp hopefully.......
Old Jan 14, 2011 | 02:09 PM
gears94gt's Avatar
gears94gt
you might be around there maybe a litlle more, 215 rwhp, 240rwtq.
Old Jan 14, 2011 | 02:21 PM
mrtstang's Avatar
mrtstang
PI cams and intake, but NPI heads? Not tuned either? If so, i 'd guess maybe 215-225 rwhp.
Old Jan 14, 2011 | 08:39 PM
tbirdscwd's Avatar
tbirdscwd
That sounds about right
Old Jan 15, 2011 | 12:03 PM
jstang909's Avatar
jstang909
cool thanks a tunes coming soon but after a few more bolt ons. i hope to be sitting at almost 250ish rwhp with pulleys ,headers, o/r xpipe, and a tune
Old Jan 15, 2011 | 02:12 PM
grogan's Avatar
grogan
i put down 260rw on full bolt ons. long tube headers, cai, pulleys, tune, 4.10s, 3k stall converter, 75mm tb and plenium. already had the pi setup since im a 03. then i stepped it up to a vortech and im at 475rw.
Old Jan 15, 2011 | 02:20 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Dont hold your breath man. if your ~215 now idk if those mods are good for 35 moe rwhp.. I hope you get your goal however. How soon until dyno day
Old Jan 15, 2011 | 03:33 PM
98redstang's Avatar
98redstang
you have a pi motor so your rwhp gains are gonna be nowhere near an npi motor.
op your around 210-220rwhp if i had to guess. I would do a full pi swap for your next mod.
Old Jan 15, 2011 | 07:37 PM
grogan's Avatar
grogan
right but i figured with him doing the pi swap other than his pistons, they should be the same. he would produce more power being a higher compression and n/a
Old Jan 16, 2011 | 12:16 PM
TRUEBLUE3934's Avatar
TRUEBLUE3934
You may come up a little bit short of your hp goal, but I wouldn't put much value in the dyno number anyway. Take it to a track before and after your next mods and see what impact it has on your trap speed. Trap is a much better indication of your power anyway. It is a good measure of power to weight ratio, without much impact from traction, etc.
GOOD LUCK with the new mods!
