Tremec Shifter Problem
Old Jan 15, 2011 | 03:00 PM
CarAudiophile's Avatar
CarAudiophile
Default Tremec Shifter Problem
Ok well I have been having problems getting the car into gear. Got underneath it today and found this What do you suggest I order to fix it. I know New Clutch Cable Assembly (will order adjustable) but what is that lever I need to order, and who from?
FYI I bought the car 2 days ago
Tranny is a TK0600.
Old Jan 15, 2011 | 03:34 PM
lizzyfan's Avatar
lizzyfan
Underboss
Just get an OEM cable
If you don't have already, get an aftermarket quadrant and firewall adjuster
Old Jan 15, 2011 | 03:43 PM
CarAudiophile
The big issue is the fubared clutch fork. Where do I source one. Or do I use a stock ford one?
Old Jan 15, 2011 | 03:45 PM
lizzyfan's Avatar
lizzyfan
Underboss
Stock Ford
Old Jan 15, 2011 | 04:02 PM
CarAudiophile
That's a relief. Will go to ford on monday. Thanks. Thought it was a tremec part
Old Jan 15, 2011 | 04:03 PM
CarAudiophile
Does it look like it broke then some one patched it with that metal piece?
Old Jan 15, 2011 | 09:01 PM
lizzyfan's Avatar
lizzyfan
Underboss
Looks like it was maybe a clutch fork from a Fox tranny which is shorter and kinda jury rigged it
Old Jan 15, 2011 | 09:03 PM
lizzyfan's Avatar
lizzyfan
Underboss
BTW,
Kinda interested to see how your TKO600 shifts
Once you get it back together give me a report
Old Jan 16, 2011 | 06:33 AM
CarAudiophile
I can tell you when it does work I have a boner. I should have everything ordered up next week.
Old Jan 16, 2011 | 07:50 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
I have seen that done as a half-assed attempt to lighten the pedal effort as well
