Give me some head(s)!
Old Feb 11, 2011 | 04:03 AM
ahriman's Avatar
ahriman
Roidrage = Banned
Default Give me some head(s)!
i was thinking about swapping my heads with iron 2v heads.... what do u guys think?? how much hp will i gain? they will be stock 1998 gt heads. they will not be ported because i dont believe in porting.... i am going to put really stiff valve springs though.... i am also going to clean the heads with soap and water before installing them.... i might try to open up the ports a little bit with some sand paper...
Here is my budget so far:
cast iron non pi heads- $1000
sand paper- $10
brake delete- $60
soap and water- $1
Old Feb 11, 2011 | 06:20 AM
mrtstang's Avatar
mrtstang
Lol....
Old Feb 11, 2011 | 06:22 AM
PurpleIcedGT's Avatar
PurpleIcedGT
Lmao.....
Old Feb 11, 2011 | 08:10 AM
teej281's Avatar
teej281
4.6L Section Moderator
wow...
Old Feb 11, 2011 | 08:30 PM
BraMas's Avatar
BraMas
is this an attempt at being funny?
Old Feb 11, 2011 | 08:42 PM
MCxQubed's Avatar
MCxQubed
already banned lol, this is just stupid
Old Feb 11, 2011 | 08:52 PM
DreamerGT's Avatar
DreamerGT
sand paper- $10
brake delete- $60
soap and water- $1
you should gain about 192hp your set up
Old Feb 12, 2011 | 12:04 AM
Xemeth's Avatar
Xemeth
**** cast iron. What you want are brick heads. They're pourus so they flow the best. Also, stick some small rocks or gravel in the coolant and oil passages. Who wants to get their brand new heads dirty with all that oil. Yuck!
Oh, almost forgot. Make sure you get porceline valves and use a bunch of small slinkies for valve springs. They reduce rotational mass making for a smoother running engine. And no headers, either. Open exhaust ports for the best airflow.
That setup should produce untold amounts of power.
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 27, 2015 03:16 PM
