Brake light Mod
Old Feb 13, 2011 | 09:37 PM
stanglx2.3's Avatar
stanglx2.3
Default Brake light Mod
I have a 99 cobra with the amber turn signals. One cracked so instead of paying $279 for a new on I bought a set of all red for $55.
I have 5 bulbs (one for the amber turn signal) and the GT Light only has 4 holes. I was thinking about cutting out the twist lock out of the Cobra light and drilling into the same spot on the GT one.
I am open to other ideas, I just want the turn signal to work some how some way. Thanks for the input.
Old Feb 14, 2011 | 02:00 PM
Brute03's Avatar
Brute03
i think your cheapest option would be to drill a hole for the fifth bulb and stick it in there with RTV. there seems to be a spot that you can just punch out on the lower right-hand corner where the cobra turn signal usually goes
Old Feb 14, 2011 | 02:55 PM
Z28KLR's Avatar
Z28KLR
Go to a junkyard and pull the lamp harnesses from a non Cobra car, or better yet order a sequential harness kit.
Old Feb 19, 2011 | 09:59 AM
stanglx2.3's Avatar
stanglx2.3
[QUOTE=Brute03;7417981]i think your cheapest option would be to drill a hole for the fifth bulb and stick it in there with RTV. there seems to be a spot that you can just punch out on the lower right-hand corner where the cobra turn signal usually goes
How would I get the bulb out for replacement? It looks like it is a cap, and I just need to get it off somehow.
MustangGirl98
Aug 2, 2016 08:10 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
bond007
Aug 26, 2015 11:36 PM
cody.hoeppner
Aug 12, 2015 06:39 AM
cody.hoeppner
Aug 11, 2015 08:08 PM
