Torn between performance or looks!
Old Feb 15, 2011 | 09:09 PM
huey_33's Avatar
huey_33
Originally Posted by H0SS302
Cobra badges also. Those are good for +20 shield and +5 Hit Points.
Might have to consider that!
Old Feb 15, 2011 | 09:15 PM
mrtstang's Avatar
mrtstang
Originally Posted by huey_33
Gears it is!! What other parts should be replaced when installing gears? Should I also get the installation and bearing kit or will the old ones work?
That depends. If you have more than 80,000 miles or so it wouldn't hurt.
Old Feb 15, 2011 | 09:16 PM
natedog's Avatar
natedog
I vote gears as well, but think about what you will enjoy more. Are you more of a performance guy or a looks guy?
Btw, I have been wanting to install my gears and had a question. Can any ole mechanic correct my speedo or do I have to take it to a stealership if I don't buy a speedcal?
Old Feb 15, 2011 | 09:18 PM
PurpleIcedGT's Avatar
PurpleIcedGT
You should be able to correct it with your tuner nate...
Old Feb 15, 2011 | 10:46 PM
natedog's Avatar
natedog
I don't have a tuner. Basically I'm trying to get around having to buy one. Is it possible?
Old Feb 16, 2011 | 12:45 PM
fordadvisor's Avatar
fordadvisor
Default reply to natedog
natedog is your mustang a manual or auto
Old Feb 16, 2011 | 08:38 PM
945LSTANG's Avatar
945LSTANG
It says he has a steeda tri-ax, so manual.
OP: gears are big on the list, but I can't stand looking at a 4x4 mustang. I probably would've done the springs first.
smitty2919's Avatar
smitty2919
gears and cut your stock springs.
Old Feb 16, 2011 | 10:25 PM
PurpleIcedGT
This is Smitty reporting for MF100-news from Kentucky, the land that doesn't receive mail on time....and I approve this message.
Old Feb 16, 2011 | 10:34 PM
TRUEBLUE3934's Avatar
TRUEBLUE3934
Gears should be the first mod on any Mustang if performance is desired. The factory gears are too tall and kill your accelleration. You will not regret doing the gears.
Advice, for what it is worth...
Be sure to get an experienced mechanic to install the gears.
Unless you have a low mileage Mustang, replace the bearings and seals now while you are in it. It costs a few dollars, but now is the time to replace the old stuff.
Don't go out jammin gears as soon as the car rolls out of the shop. Take it easy on the new gears for 300-500 miles while you heat cycle the gears a bit. You'll get all kinds of differing advice on that, but there is no good reason to take a chance with them if you can simply wait a week before hammering them.
Enjoy the new car once the gears are in!!!
