ISO's in or out, or a mix?
Ok as some of you know I'm putting an Eibach Pro kit on my 2000, but I have been debating leaving the ISO's in or not. I'm between getting some replacement poly ISOs from AM or none at all and just wrapping the springs with tape and or shrink wrap. I was also thinking of keeping just my rear ISO's in (replacing with new poly ones) because I have heard the rears being out makes the ride a lot worse.
Pro's to removal:
1) Cheaper
2) Lower (but only about a 1/4 inch in the rear from what everyone says, so its not much)
3) Better steering response and road feel
Con's to removal:
1) Stiffer ride
2) Noise/squeeky suspension
3) Lower and may not be able to align car w/o CC plates (trying to get away w/o buying these)
So what are you opinions on this? I'm using the car for strictly a DD which is the only reason I'm debating leaving them in, I don't track the car or beat it up to bad around corners since I'm driving on the street. I know I would enjoy the little lower look and better steering response though. Plus it saves some money by not buying new ISO's.
Pro's to removal:
1) Cheaper
Con's to removal:
1) Stiffer ride
Ask yourself this: Will you be happy with the drop that the pro-kit gives you? If you think not, you might want to pop the isos out, but obviously you run the risks that you mentioned above. A bunch of people can come on here and say they have no issues with the isos out, and then you do it and have issues. I guess you'll never know until you try it.
I'm actually considering this as well, cause i'm not happy with the stance of the pro-kit. If you decide to do it let me know how it works out for you.
Ok, here are your choices...
1. use the poly iso's and add ride height to the already horrible drop that the pro-kit gives.
2. use no iso's and run the possibilites of not being able to get a proper alignment
Or you could have made some decisions first and picked some H&R SS springs and bought the poly iso's to add a little bit height and been happy with the drop and been able to get the alignment reasonably close.
Pays to do some research and some thinking ahead of time before the purchase.
I would say you may want to leave them in. I'm facing the same debate with my H&R SS I bought. I think when it comes down to it, I may leave mine in, then if I want it lower I'll take them out once the springs settle. But since you're trying to get away with not having to purchase CC plates, you may want to leave them in for now. Or you could always flip a coin....
Pays to not jump to conclusions as to not look like an asshat.
Also how hard is it to swap springs? I have everything needed to do the job, spring compressor and all that, knowledge about wtf I'm doing. But can I swap springs without removing much at all? It looks to me like it's pretty easy on these cars but maybe I'm wrong. Maybe I'll start w/o them and if it's that bad I'll pull the springs again and put poly ISO's in.
I did make some decisions. That's why I bought the pro kit... I didn't want the drop the H&R's give because it's too much for a DD in my area. Plus IIRC the H&R springs ride harder which I didn't want. Plus I got a killer deal on the Eibach Pro suspention kit, paid 300 for a 600 dollar kit. I think the Pro kit with the ISO's removed would give me the drop I want, but I'm worried about the ride. That's why I may just leave the rear ISO's in.
/sarcasm
The reason I said that was because you're going to get supersport drop out of the prokit without the iso's and almost stock if you get new iso's. So you're kinda in a situation where Supersport springs with new iso's would have been perfect for you. Thats what I'm saying. Sucks that those springs came in your kit and not sportlines. And to think that pro-kits are gonna ride better than any other lowering spring is kinda not accurate. I've owned prokits and they sucked. Rode in a car with sportlines and rode the same as mine did and looked a hell of a lot better. And buying new iso's is a waste of funds. Your car came stock with iso's that work just fine. No need to blow more money on something like that IMHO unless your iso's are completely and utterly useless.
