Mid-pipe Install
Old May 4, 2011 | 07:53 PM
speedkills's Avatar
speedkills
Default Mid-pipe Install
My MAC o/r x pipe just came today! I'm hoping to install it sometime over this weekend. It will be my first time installing a mid-pipe and was wondering if anyone has as hints, tips or just general advice. Any would be greatly appreciated. Thanks.
Old May 4, 2011 | 08:28 PM
harbre32's Avatar
harbre32
Swivel socket and extensions
Old May 4, 2011 | 09:43 PM
huey_33's Avatar
huey_33
^^+1. Alot of patience and some PB blaster for those stubborn bolts. I did it a couple years ago in my garage because I didn't have access to a lift. If you have access to a lift, use it!!! If you dont, once you get the mid-pipe bolted up to the manifolds, use a scissor jack to hold it up so you can bolt it up to the catback.
Old May 5, 2011 | 06:01 AM
uberstang1's Avatar
uberstang1
Chupacabra
Soak the bolts with penetrating fluid and let it sit awhile, you can also let the car run abit to heat up the bolts, its a very easy job unless you break one of the studs off the manifold then it becomes PITA.
Old May 5, 2011 | 10:20 PM
speedkills's Avatar
speedkills
Thanks for the advice everyone. Now I know the o/r pipe will cause a check engine light and this can be corrected with a tuner. I am in the process of buying a tuner and it probably won't be here until after I install the mid-pipe. So will it be ok to ride around for a few days with the o/r mid-pipe untill my tuner gets here?
Old May 5, 2011 | 10:39 PM
huey_33's Avatar
huey_33
It will be perfectly fine to drive your car around for a few days with the CEL on. If you want to go a cheaper route than buying a tuner, try these. They are made specifically for mustangs with O/R pipes that don't have cats.
http://www.americanmuscle.com/stmilel.html
Old May 5, 2011 | 10:50 PM
speedkills's Avatar
speedkills
Ok awesome. I thought about buying those but decided it would be a better investment to buy a tuner. I'm buying a used predator so it isn't that much more expensive.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
