help please?
Old May 15, 2011 | 08:27 PM
Fanatic462's Avatar
Fanatic462
Default help please?
I recently bought a 02 Mustang GT and when i start it up it fires up but then kinda just dies. I normally do that 2-3 times be4 it stays running and soon as its running its perfectly fine. anybody know what going on? My roommate says it could be the fuel pump.
Old May 18, 2011 | 07:48 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Is this with a hot or cold engine--or both?
What happens if you just cycle the key between RUN and OFF (keep it in RUN for 3-4 seconds) 4 or 5 timers before actually trying to start the engine. This will cause the fuel pump to run for 1-2 seconds each time you cycle the key; it may be some sort of fuel pressure issue at start-up.
If it starts and runs after cycling the key a few times (or not) let us know...
