some upgrades
Old May 18, 2011 | 11:00 PM
sdmfanderson's Avatar
sdmfanderson
Default some upgrades
I was thinking bout doin some upgrades on my car to get some more hp out of it.i have a 96 gt.I currently have cold air intake and exhaust.thats about it.I was thinking about doin underdrive pulleys, bigger mass air flow, headers and throttle body.are the parts worth it if?
Old May 18, 2011 | 11:59 PM
0949er's Avatar
0949er
you are better off saving up and doing a PI swap. All those might net you some HP, but nothing really worth it.... (I say that though speaking from a pure opionion, I would personally prefer the heads & cams)
Old May 19, 2011 | 12:25 AM
Crazycarnut's Avatar
Crazycarnut
I would do that or go with gears. Depends on the budget that you have though really and what you want out of the car.
Old May 19, 2011 | 12:33 AM
tdcalhoun89's Avatar
tdcalhoun89
@least 4.10 gears, PI swap, some sort of exhaust upgrade to make it sound better, a short shifter for the fun factor, and suspension components.
F/I if you want a lot of hp.
I wouldn't screw around with anything else until I did that stuff first.
Op, what are your goals for the car? Is if a DD, weekend fun car, toy? If you tell us what your goals/uses are for the car, you'll get a much better response and better feedback. Good luck.
Old May 19, 2011 | 12:45 AM
sdmfanderson
Thanks for your responses.It is my daily driver, but i also like to have some fun in it.i was lookin to add a little hp.Im not usin it as a track car so i dont need to make it super fast.But i want to bump the hp up a little bit
Old May 19, 2011 | 02:38 AM
AJB540's Avatar
AJB540
Forget putting anything into your current motor and put a 5.4 4v.
That's what I'm planning on doing at least >_>
Old May 19, 2011 | 04:09 AM
Crazycarnut
If you want a bump in power I would do gears, and then heads and a tune (heads and tune together)
Old May 19, 2011 | 05:23 AM
uberstang1's Avatar
uberstang1
Chupacabra
gears, 4v swap, supercharger.
Old May 19, 2011 | 07:41 AM
mrtstang's Avatar
mrtstang
A set of gears at bare minimum. How much do you want to spend?
Old May 19, 2011 | 11:56 PM
sdmfanderson
I forgot to add i have 3.73 gears and a sct tunner. Im lookin at a grand or less.Like i said im not tryin to make it into a strip car its mydaily driver but im just lookin for a little extra to have some fun in it. Thanks for the advice guys
