FLSFC
Old May 30, 2011 | 05:27 PM
jtb727's Avatar
jtb727
Default FLSFC
So I did some seraching, and nothing really helped, Are the AM subframe connectors adequate? Or are they really cheesy? I think I made a misake, I bought some that are still in the box and in their bubble wrap from CL, but they're the AM ones.... Kinda feelin like I wasted $70 smackers..
Old May 30, 2011 | 05:32 PM
H0SS302's Avatar
H0SS302
as long as there full length, they will be worth it.
Old May 30, 2011 | 05:36 PM
jtb727's Avatar
jtb727
Yes, they're the weld in and full length ones... I kinda had that bad feelin in the stomach once I got them home and looked at them much closer, other than making sure they were full length, and truely not mounted like the guy said.. Guess I'll throw em in, they cant hurt huh?
Old May 30, 2011 | 05:37 PM
jtb727's Avatar
jtb727
Thanks Hoss,
Old May 30, 2011 | 05:40 PM
lizzyfan's Avatar
lizzyfan
Underboss
I have the AM SFC's (J&M) and they are fine
Old May 30, 2011 | 05:44 PM
jtb727's Avatar
jtb727
Did you notice a difference with them? Where all did you weld yours at?
Old May 30, 2011 | 05:47 PM
Aereon's Avatar
Aereon
The only thing about sub frames and our cars' is that when the welder welds them in make sure the car is lifted by it's wheels and not a 4 post lift. Then make sure that the sub frame contours to the car and is not bent to fit the frame, the car's frame will warp to the contour of the flsfc if the shape of the flsfc's is off. For this reason I'd only recommend MM, Griggs, and Meiar racing flsfc's because I've seen in person that they fit the contours of the undercarriage perfectly as they should.
Old May 30, 2011 | 05:49 PM
lizzyfan's Avatar
lizzyfan
Underboss
Yes, tightened the car up immensely!
Had a shop weld mine on
Old May 30, 2011 | 05:52 PM
jtb727's Avatar
jtb727
What'd it run to get em welded in?
Old May 30, 2011 | 05:53 PM
jtb727's Avatar
jtb727
Aereon, these ones are pretty straght...
