99 Mach 460 ?'s
So I know that in 01 they changed the headunit configuration for the mach audio. Has anyone put an aftermarket head unit in a 99 W/ the mach? What install/dash kit did you use? because they are the split headunit and CD set up, and I dont see a dash kit that is specifically for it.. Did you guys just leave the CD part down there? or...???
do the 99s have a traction control button and such? idk when that started.
Mine looks alot like that. Yes, I have a trac control button and a cig lighter.. but its under the "gauge slot" shall we reference it as. I like that idea, itd look much better with the gauges down there than up on the A piller, IMO. I'm going to be installing my transgo HD2 W/ oil cooler, and would kind of like a trans temp to keep an eye on... Arizona can be pretty brutal. So maybe Ill copy the idea.. how flush does the wood fit with the backside of the bezel right there? or is there some gaps?
I have a 98 with a pioneer head unit and i got both the fm/am tuner and cd player taken out. I got the head unit put in where the fm/am tuner was and the cd player i got a tray that slides right in.
http://cgi.ebay.com/ebaymotors/CAR-S...ht_2880wt_1165
This is the pocket that i have that fits a 99 also
When you guys had yours all apart, is there any way I could put my new HU in where the CD player part is? I like the way its tucked in there, mostly so it casts a shadow over the screen, and I'll be able to read the thing during the day... they look to be the same size from my eye ballin, but I havent torn it apart to see whats behind it all. Could this work? than gauges or dash cubby up top?
i dont think its enough clearance in the back, but i really havent checked cause ive never thought about that. haha good idea man. but if you have a manual it sucks because i have the pocket like i said before and i have my controls for my subs in there and i cant ever get my hand down in there. it would just be a hassle IMO. but good idea.
down shift, hammer the throttle and turn up the tunes man
but on a serious note, I'm an auto, so while driving, the way the shifter sits, and the placement on the bottom is also much more comfortable for my hands vs. having it up top.. and the shifter is always back( as if you were in 4th) whenever I'd be messin with it, and my bass **** is going to be where my cig lighter in the console is. I do some custom audio stuff, as far as boxes, amp racks, and wiring.. I like to keep the head unit installation stock as can be for comfort, and the fact that it just fits better. I just didnt see any write ups for these dashes.. I'd really prefer the cubby up top.... hmmm...
