vibration at 55plus, driveshaft
Old Sep 15, 2011 | 07:37 PM
ctgreddy's Avatar
ctgreddy
Default vibration at 55plus, driveshaft
I put new ujoints in my driveshaft, and now from 55 on up there's a slight vibration. i marked everything when i took the flanges off so it's back on how it was, and the new ujoints all move freely and easily. I'm gonna steal my buddies aluminum shaft this saturday just to make sure that's what it is causing the vibration. but why would it just start vibrating? could i have knocked it out of balance somehow since i was jerking it around a bit putting the new parts in?
Old Sep 15, 2011 | 09:42 PM
dominant1's Avatar
dominant1
i know you shouldn't have to re-balance your drive shaft after a u joint change but you may want to have it professionally balanced anyway, otherwise just buy a ford racing aluminum drive shaft...
Old Sep 15, 2011 | 10:00 PM
ctgreddy's Avatar
ctgreddy
well i took my buddies frpp one, and his was a stick so i put my trans flange on along with the new ujoint that i had already on that flange, and put them on his frpp shaft. bolted that in and it rides good again. so it's either the driveshaft is out of balance now or somethings wrong with that other ujoint.
Old Sep 15, 2011 | 11:25 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Whack the U-joints with a hard rubber hammer, from a number of angles (rotate the d/s while whacking away). This will often force the joints to settle in to their natural positions after being remounted...
Old Sep 16, 2011 | 06:02 AM
ctgreddy's Avatar
ctgreddy
I did that before i put it in the first time.
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
