is it true
Old Nov 2, 2011 | 07:19 PM
Repzard's Avatar
Repzard
Originally Posted by Bpohlman13
You should also replace your headlight fluid every time you put new light bulbs in. Just saying.
Also check the blinker fluid
Old Nov 3, 2011 | 11:11 AM
hpwrestler220's Avatar
hpwrestler220
**** i just replaced a headlight bulb in another car and i forgot to change the headlight fluid! This one is going to blow out too now
Old Nov 3, 2011 | 03:32 PM
uberstang1's Avatar
uberstang1
Chupacabra
Why the motor is out its a good time to replace the muffler bearings on the stock exhaust manifolds.
Old Nov 3, 2011 | 04:09 PM
Sxynerd's Avatar
Sxynerd
I thought the access point to those was under the seats and carpet? Ah, it must have been a Mid production year changeover. Best bet would be to take out the interior before he pulled the motor. ...you know, to save him some work.
Old Nov 3, 2011 | 06:20 PM
uberstang1's Avatar
uberstang1
Chupacabra
+1 I forgot about that.
Old Nov 3, 2011 | 06:49 PM
02GTman's Avatar
02GTman
Is the radiator recalibration tool a special order? I wonder if Harbor Freight tools has them? I have looked every where.
Old Nov 3, 2011 | 08:51 PM
BraMas's Avatar
BraMas
I seen a Radiator calibration tool at Harbor freight but is is Nuclear powered and expensive. I also heard you can re-calibrate the Radiator by using a toilet plunger on where the Rad cap goes. I think it about 20 up and down cycles and you should be good to go
Old Nov 3, 2011 | 09:13 PM
Bpohlman13's Avatar
Bpohlman13
I thought it was 24 down cycles, and then 25 up cycles? Correct me if Im wrong though.
Old Nov 4, 2011 | 12:24 AM
scott4.6's Avatar
scott4.6
Dont forget to change the spark plug coolers.
Old Nov 4, 2011 | 12:40 AM
turbo232's Avatar
turbo232
yeah...those are very important for intake temps.
