thump near axle when floored
Old Jan 25, 2012 | 10:01 PM
02mustangnewb's Avatar
02mustangnewb
Default thump near axle when floored
just bought a 02 gt, auto, all stock, seems like when cruising around 50mph, if i floor it, i get a quick "thump" from the back of the car. doesnt do it from dead stop, just when cruising at higher mph, any ideas where to start looking?
Old Jan 26, 2012 | 11:06 AM
kugzgt's Avatar
kugzgt
check your u joint and suspension bushings
Old Jan 26, 2012 | 04:09 PM
02mustangnewb
I was thinking u joint. But its only at high speed. Would think u joints would be constant ??? I just bought the car. And the guy lived in boo foo on a dirt road so suspension might be spot on
Old Jan 27, 2012 | 09:40 AM
TRUEBLUE3934's Avatar
TRUEBLUE3934
Agree that it not happening from a stop or low speed doesn't make sense..., but loose control arm mount is my first guess. However, I would expect that to make noise besides just punching it at speed as well. The axle housing torques over under acceleration and changes the load on different components in the suspension.
While driving down the road, the u-joints are already under load so it shouldn't be a u-joint taking up slack.
Good luck locating the source of your noise!
Keep us posted on what you find.
Old Jan 27, 2012 | 02:15 PM
02mustangnewb
Will do. I'm getting 4:10s and aluminum shaft. So hopefully I will see it when I'm down there
Old Jan 27, 2012 | 03:52 PM
TRUEBLUE3934
Take a good look at the torque boxes while you are under there as well.
You will love the improvement in acceleration with the 4.10 gears!!! You will find yourself rowing thru the gears a lot more quickly when pulling off from stop lights, etc.
Old Jan 27, 2012 | 05:58 PM
02mustangnewb
I hope so!!! I was gonna go 373s. But a lot of people say if the auto to go 410s
Old Jan 27, 2012 | 05:59 PM
02mustangnewb
If you have auto trans to go 410s. *
Old Jan 27, 2012 | 09:24 PM
TRUEBLUE3934
I see now that you had mentioned it being an auto trans.
You will like the 4.10 gears. They are a huge improvement over the stock ratio.
Old Jan 27, 2012 | 11:01 PM
02mustangnewb
i sure hope so, 4.10s , and a tuner coming this week for sure!
baddog671
Jul 26, 2016 01:20 PM
b8checker
Oct 8, 2015 12:55 PM
KingRando
Oct 2, 2015 08:06 AM
b8checker
Sep 30, 2015 07:11 AM
Sep 24, 2015 09:18 PM
