need help installing stock springs
Old Aug 19, 2012 | 11:12 PM
matt1990's Avatar
matt1990
Default need help installing stock springs
long story short im selling my mustang to buy another one. I switched out my rear springs no problem and pulled out my front H&R springs but now i have to re install my stock springs in the front but no matter how much i try to muscle them in they just wont fit, not even without isolators. does anybody know a trick to get them in? the calipers and struts are disconected
Old Aug 20, 2012 | 12:12 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Did you disconnect the stabilizer links?
Old Aug 20, 2012 | 08:06 AM
uberstang1's Avatar
uberstang1
Chupacabra
Disconnect sway bar, disconnect shocks, disconnect quadshocks, disconnect caliper, jackstands under torque boxes, jack under rear, lower untill spring slides in, with stock springs a compresssor may be necessary.
Old Aug 20, 2012 | 08:57 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
It's the front he is having trouble with...
Old Aug 20, 2012 | 09:57 AM
uberstang1's Avatar
uberstang1
Chupacabra
Good ole monday mornings, put jack under a arm, disconnect tie rod end and strut, use spring compressor, insert spring, jack up on a-arm, reconnect tie rod and strut bolts.
Old Aug 20, 2012 | 10:53 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
^+1, caught me too--I forgot about the tie-rods...
Old Aug 20, 2012 | 12:16 PM
uberstang1's Avatar
uberstang1
Chupacabra
and i forgot the sway bar end links, gonna be a rough week.
Old Aug 20, 2012 | 01:16 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Look at the bright side, it has to get better.
I think when you have done this crap as much as we have there are a whole bunch of things to be done that we do not even think about. I wrote a quick "How to pull the tranny" list for a friend and left out 4 or 5 "steps" that I probably would not have remembered doing if I had just got done pulling one out...
Old Aug 20, 2012 | 02:05 PM
1998Slow 'Stang's Avatar
1998Slow 'Stang
You will need a spring compressor to get stock springs back in.
I've tried without and it does not work, also I think that it is 100% easier to use the type of spring compressor meant for macpherson/coil over shock style springs as the holes in the bottom of the control arms is not large enough to accomodate the conventional spring compressor.
However if you cut a coil from the front they go back in easy as cake, and you get to lower the car...haha.
Old Aug 21, 2012 | 08:22 AM
uberstang1's Avatar
uberstang1
Chupacabra
I use tradition coil compressor, the profesional product one fits through the a arm on the bottom, I can't stand mcpherson compressors there a massieve PITA.
