Transmission help
yeah doyon they're a lot cheaper than that, for what you would need, trans, bellhousing, driveshaft, and possibly crossmember(not sure if they're different or not) i would expect to pay around 2500-3k for one out of a cobra. with that said the totally stock unit will handle that power range. only big thing you'd have to do for more horsepower than what you said would be a 26 spline input shaft. those are a little over $300 and with that you could handle 6-700whp.
I ordered a rebuild kit, with all the upgraded parts for the problem gears I've been having and found a highly reccomeded local shop that will do the labor and a bonus I know the owner and he will cut me a deal on labor l. Thanks for all the help ctgreddy I'm dying to be able to drive my car again it's like I'm having withdrawals
How is 3-4K massive expensive for a magnum conversion?.. And I would never trust a 3650 for high torque, even if it's built..
Because you can get a built 3650 for 2-2500, and it direct bolt up. You can also get a built t45 for around that as well. ALOT of high torque cars run built 3650s without issue. 4k for a magnum setup in my opinion is expensive. 1. If its a street car that sees occosional track use a built 3650 will hold up just fine. 2. If its a designated track car, well, sticks are usually out the window if you wanna compete youll be running a built c4, powerglide, th400, th350. And you can get a bullet proof auto setup for even less that 4k for that magnum setup. I'm curious to what parts in the 3650 you are afraind of that your not afraid of in the t56.
Just not worth it in my opinion.. It's not a sturdy transmission at all. If it's just street that's different, but for heavy use and hard shifting I wouldn't use one.. Everyone has there opinion though, I just lean to the safe side for everything.. I agree that an auto is much cheaper and easier to hold power..
Not arguing with you man.. To each their own.. I recommend a T56.. you recommend a 3650.. It's just preference.. I've used them, they're easy, they're smooth, just what I would go with over a built 45 or 3650
I understand but in this scenario, a roughly 300 horsepower street car, putting a transmission in that would cost half the price of what the cars worth is just a little out of hand. Not to mention an extra labor charges/parts to make it work if he has to take it to a shop just isn't even remotley worth it for the OPs case.
