damaged passenger door - opinions on repair? pics inside
4 Attachment(s)
I managed to damage my passenger door in a friend's parking garage that is currently under construction. My own stupidity.
Anyways, what do you suggest - repairing the current door, or replacing the door with another used door? I found a few doors locally between $75-$125 complete with mirror/glass/etc. I do not want any body filler if they repair the old door as I am afraid it will not look the same as factory when repaired. If I get a used door, I am going to have to have the back-side/jambs sprayed because I want it to match as if it came with the car. Do convertable cars use the same doors as the coupes? Anything else to watch out for if buying a used door? Is the glass easily transferrable from one door to another (I want to re-use my current glass because of the shade of tint on it). Attachment 74519 Attachment 74520 Attachment 74521 Attachment 74522 http://i6.photobucket.com/albums/y24...ngdamage05.jpg |
well you should be able to buy a new door skin for not too much then you'll only have to paint the skin itself which is the outer portion. Take it to a few body shops and see what they suggest from either a new skin or used door. i'm not even going to ask how the hell you did that lol.
Ouch, that sucks man.. but like what crgreddy said a new skin shouldn't be too bad. I doubt you'll need a new door unless something internally was also damaged..
Whateve you do, do it right. That's a gorgeous car.
