HOLY SMOKE
Old May 1, 2013 | 04:09 AM
Al Saggese's Avatar
Al Saggese
Default HOLY SMOKE
My 98 GT only smokes after it hits a certain temperature after that it smokes out of the tailpipes.If it's cool out it will run all day with out a hint of smoke,going crazy trying to figure this out.TIA.
Old May 1, 2013 | 08:28 PM
Al Saggese's Avatar
Al Saggese
Holy smoke over 130 veiws somebody help me please getting ready to shoot this horse.
Old May 2, 2013 | 07:25 AM
Vertigo_GT's Avatar
Vertigo_GT
Hold your fire Al. You have a tough one. The smoking is affected by the weather? What color is the smoke? Are there any noises or is the CEL coming on?
Old May 3, 2013 | 12:10 PM
Al Saggese's Avatar
Al Saggese
NO just the temperature as soon as it reaches the same spot on the gauge.white smoke if i open the egr by means of straight vacuum it stops instantly.
Old May 3, 2013 | 12:26 PM
Vertigo_GT's Avatar
Vertigo_GT
Bad EGR increases emissions. I'd replace it. The picture provided at the below link about symptoms of a bad EGR Valve is of a tailpipe emitting white smoke.
http://www.ehow.com/about_6157262_sy...gr-valve_.html
Increased Emissions
The EGR valve's main purpose is to aid in the reduction of noxious gases produce by the engine. It does this by lowering the temperature of the combustion process through the introduction into the combustion chamber of controlled amounts of exhaust gases. This lower temperature has the effect of reducing the amount oxides of nitrogen (NOx) produced by the engine. A faulty EGR valve will fail to properly cool the combustion process allowing these gases to increase, which can lead to an abnormally high NOx reading during emissions testing.
Read more: What Are the Symptoms of a Bad EGR Valve? | eHow.com http://www.ehow.com/about_6157262_sy...#ixzz2SFhEkTOm
Last edited by Vertigo_GT; May 3, 2013 at 12:35 PM. Reason: Added Link to Symptoms of a bad EGR
Old May 3, 2013 | 03:59 PM
Al Saggese's Avatar
Al Saggese
Thanks Vertigo GT Thats what the tailpipes look like i will have to get that fixed.
Old May 3, 2013 | 09:17 PM
Vertigo_GT's Avatar
Vertigo_GT
I hope that takes care of the problem.You nailed it with bypassing the EGR.
Jan 21, 2016 01:30 PM
RCS02v6
Sep 29, 2015 01:46 PM
MacSerio
Sep 27, 2015 01:05 PM
Ipaman
Sep 22, 2015 07:01 AM
fastbackford351
Sep 12, 2015 09:42 AM
