Tire size change to improve accel
On my 1996 stock GT, I have the Z code 3.07 gears which I understand is the std for automatic cars. I know that the car doesn't have enough horsepower, so considering a tuner. While I'm thinking on that, I don't want to go to the expense of changing gears, but I thought if I could reduce the tire size a bit it might help the axle ratio. I was thinking 245 45 R16 which would reduce the tire diameter about an inch and bring the effective axle ratio to about 3.19. Would this be a noticeable improvement in short line acceleration? Any other ideas? I don't have any shops in my area that would do a gear swap and I just serviced the differential. Thanks.
Thanks that's what I was afraid of. I don't know of anyone that does that for that kind of price. What gears are recommended BTW? I'm not concerned about mileage, or top end speed since I don't want to drag race.
For what you would spend on a new set of wheels and tires, why not consider doing something to increase power instead? PI swap comes to mind.... And will make a much more noticeable difference in your car's performance than what you're proposing and assuming you're able to get your hands dirty and diy could probably be done for what you would have spent on wheels and tires. Keep in mind that a +/- 0.19 difference in final drive ratio will be barely noticeable.
Thanks. My dad actually had a garage at one time so I am able to do some work, and I saw these but didn't know it would make a lot of difference. Probably not a bad idea since I have the old-style (recalled) plastic intake with plastic coolant runner.
245-45-ZR-17s. So, let's use that size.
First, 245 x .45 x .03937 = 4.3 inches, the sidewall width. Got 2 sidewalls plus the rim diameter, so,
4.3 x 2 = 8.68. Add 8.68 to 17 = 25.7", the "rolling diameter". Need Circumference, so 25.7 x Pi = 25.7 x 3.1415 = 80.7", the DISTANCE the car moves for one tire revolution. Change that to FEET, 80.7 divided by 12 = 6.7 feet, distance car moves in one TIRE REVOTION. How many revs per mile?
5280 feet per mile divided by 6.7 feet = 788 tire revs per mile. At 60 mph, (1 mile per minute), tire speed is 788 revs. per minute. DRIVESHAFT turns 3.08 (rear axle ratio) x 788 = 2427 revs perm minute = DRIVESHAFT SPEED @ 60 mph.
Now, the gearing. Call O/D ratio 0.67, close. Engine will be turning 0.67 x driveshaft speed = 0.67 x 2427 = 1626 rev. per minute. AT 60 mph.
Wait, he asked for 75 mph, so 75 - 60 = 15. 15/60 = .25 = 25.% higher. Eng. speed @ 75 WITH 3.08 gears = 0.25 x 1626 = 406. Add 406 to 1626 = 2032 rpm @ 75 mph.
With 4.10 gears? 4.1 divided by 3.08 = 1.33 = 133%. Eng. rpm @ 75 mph with 4.10 gears = 2032 x 1.33 = 2705 RPM!! AT 75 mph.
It's simple arithmetic, fellas. imp
