Speedometer Oil and water stock gauges not working
Old 08-16-2018, 02:24 PM
Boosted98
Boosted98's Avatar
Default Speedometer Oil and water stock gauges not working
New to the forum, Just picked up a 1998 GT w a 2008 motor swap with a Roush SC and the water oil and speedometer don't work. All the other gauges work . Any help is appreciated
Boosted98 is offline
Old 08-16-2018, 02:59 PM
08'MustangDude
Banned
08'MustangDude's Avatar
Well, FIRST, ask the previous owner if they ever worked after the swap. IF he says
no, then you got some serious work ahead of you...
You'll have to get the schematics and trace out the connections and sensors. The 2008
motor would have a different ECU, and transmission. On the trans, the output sensor would change,
which would be the speedometer. Water and Oil would also be sensors, which go through
the ECU. You can always use gauge pods for readings, putting your own sensors in...
08'MustangDude is offline
Matt's 95 Stang
11-16-2011 06:16 PM
blueshawk
03-07-2008 09:16 AM
Dennis074.0
09-13-2007 08:21 PM
ltrayne84
10-19-2006 11:57 PM
fordguy17
04-07-2005 12:06 PM
Quick Reply: Speedometer Oil and water stock gauges not working
