IAC on 02 engine
Old Apr 20, 2022 | 09:00 AM
David Griffing's Avatar
David Griffing
Default IAC on 02 engine
Hello, I have a 96 mustang GT with an 02 engine. I was wondering what IAC to put in because the computer is a 96 so therfore wouldn't a 96 IAC work better than a 02 IAC? I am confused on this and I don't want to waste 100 dollars buying one that won't work on my car.
Thanks
Note: Posted this in a another thread but I'm new and I don't know how to delete it.
Old Apr 20, 2022 | 12:07 PM
art02gt's Avatar
art02gt
I would go with the one that matches the connector on the harness. Are they both the same? Are you using a 96 computer with 02 wiring harness?
Old Apr 20, 2022 | 01:35 PM
David Griffing
yes the computer is a 96, but the engine is a 02 and the IAC seems to have already been replaced so I'm figuring the wiring harness is from an 02.
Old Apr 21, 2022 | 07:13 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
if the harness is from an 02 then the PCM and cluster have both been switched as well. or someone has done some extensive wire splicing. If your car still has the 2 coil packs and 8 spark plug wires then you still have the 96 harness. If you have 8 individual coils then someone switched harness or spliced into it.
Old Apr 22, 2022 | 06:45 AM
David Griffing
Ok. I will be trying a 96 IAC when I can finally get an OEM one from ford. Thank you all for the help.
David Griffing
Convertible Tech
Apr 20, 2022 08:53 AM
Steven88
Oct 11, 2011 08:53 PM
mjohnson6634
Sep 1, 2008 06:46 PM
johndeeregreen
Mar 27, 2008 02:14 AM
spedfarmr
Mar 8, 2005 12:41 PM
