Brake Caliper Bracket Contacts Rotor without Shims and Eats Pad Clips
Old Oct 26, 2023 | 03:31 PM
Attitudeguy's Avatar
Attitudeguy
Default Brake Caliper Bracket Contacts Rotor without Shims and Eats Pad Clips
I have a ‘00 GT that I swapped a 2003 Mach 1 rear end into. Axle came with Mach 1 axle tube bracket mounts so I upgraded to the bigger Mach 1/Bullit Rotors and Mach 1 caliper bracket after running the GT rotors and caliper brackets until it ate up 3/4s of my pad 🤣 Had no problem with GT rotors and brackets just not spaced correctly bc of the Mach 1 using a taller rotor. After swapping to all Mach 1 hardware the outer of the bracket would contact the rotor so I shimmed the top and bottom of the bracket. Any fix to this issue of using shims or eating pad clips? My car likes to eat brake pad clips and am wondering if this is my issue. Thanks.
Markmartinfordfan
Mach 1 Section
Mar 3, 2015 12:57 AM
mach120
Aug 12, 2012 01:15 PM
TheCrimzonKnight
May 12, 2009 07:38 PM
dsg04gt
15
Feb 17, 2007 10:36 PM
