Limited Slip Diff.
Old Apr 10, 2009 | 10:18 PM
clfrye's Avatar
clfrye
Default Limited Slip Diff.
I am considering a new limited slip differential. My car will slip to the side on hard launches. Will a limited slip differential improve power going to both wheels significantly better? And if so, should I go with new rear axles as well. I will be putting a new motor in the car in about 6 months, with forged internals, so I can take the boost up. I am shooting for ~550 to 600 rwhp. This is a street car that may see a road racing course, for a track day, a couple times a year. So corning characteristics are very important to me.
These are the two models I am considering: an OBX Helical LSD or an Eaton Detroit True Trac.
Old Apr 11, 2009 | 04:41 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Thats should solve your issues!
Old Apr 11, 2009 | 07:27 AM
Chopper's Avatar
Chopper
I have a Tru-Trac and the "one wheel peel" is history.They do make a knocking noise at low speed but the stereo covers it up even at low volume levels.
I can definately recommend this product.
Old Apr 11, 2009 | 11:16 AM
157dB's Avatar
157dB
Cut & Paste Expert
Thats the ticket.
See if anyone local has done the swap
and knows about the axles needed.
Old Apr 11, 2009 | 11:33 AM
Shadow7874's Avatar
Shadow7874
Dont our cars already have limited slip? My window sticker says 3.31 limited slip rear under options i thought. Am i wrong?
Old Apr 11, 2009 | 02:56 PM
SCCAGT's Avatar
SCCAGT
Yes, it is already on the car. However, it is made for everyday use and not going to cause extra NVH issues. Getting something else, like what is mentioned above, will be better able to deliver an excessive amount of power to the ground in racing conditions.
Old Apr 11, 2009 | 03:57 PM
Stkjock's Avatar
Stkjock
Retired Mod
trutrac's been working well for me for going on a year+ now and plenty of track passes
Old Apr 11, 2009 | 05:34 PM
Simon1's Avatar
Simon1
You don't need new axles. The stockers are plenty strong enough and if you break one you just replace it.
Old Apr 12, 2009 | 09:50 AM
drbobvs's Avatar
drbobvs
Tru trac FTW. No issues here. As long as you're going FI and increasing power I would recommend that. IF you're going to stay NA then the stock diff is just fine. You should NOT have "one wheel peels" with the stocker. If you do then there's something wrong.
But I am familiar with your sideways slide problem and there are several things you can do to stop that. First of all make sure the tire pressure in each rear tire is exactly the same. I'm sure this sounds obvious but you'd be suprised what 1 psi can do when burning out. Next, I see you've installed a stiffer rear swaybar. This probably helps some. Lastly, and most important, stiffen up the rear D-spec on the side the car slides away from, or loosen the shock on the side the car slides to. Keep fiddling with this and it should correct most of your problem. Good luck.
Old Apr 13, 2009 | 11:23 PM
Mjwarren00's Avatar
Mjwarren00
That will fix your problem for sure.
JoshyGT
Sep 19, 2017 08:52 PM
firehorse02
Nov 16, 2015 11:28 AM
TCStangerv6
Oct 11, 2015 05:57 PM
treesloth
Sep 28, 2015 07:03 AM
Sep 8, 2015 11:50 AM
