Need Help!!!
Old Jan 5, 2007 | 05:46 PM
bascho's Avatar
bascho
Default Need Help!!!
I haven't driven a manual trans06 Mustang GT other than my brother's Roush since before I bought my 06 GT auto. In my auto, the car pulls all the way to the shift point (about 6,000rpms. In mybrothers Roush, the car stops pulling at 4,200rpms. I thought that he might have a bad knock sensor (false detonation)that was causing the PCM to jump into safe mode. He took the car to the dealer and they used a data logger.......no codes.
Has anyone had a similar experience? This is not a intermittent issue.....it's always dropping off at 4,200rpms.
Old Jan 5, 2007 | 06:03 PM
P Zero's Avatar
P Zero
Default RE: Need Help!!!
Either the cam timing is off, and if Im not mistaken the new stangs have variable valve timing. It could be that its not advancing when it should.
-P.
Old Jan 12, 2007 | 03:01 PM
2oo5stang's Avatar
2oo5stang
definitely something wrong, my car feels strong from 3K-6K rpms. did you have them test drive it?
Old Jan 13, 2007 | 12:42 PM
bascho's Avatar
bascho
ORIGINAL: 2oo5stang
I didn't go with my brother to the dealer......but he said they test drove it and data logged on the test drive. No codes. Yesterday I started thinking it might be the air filter. Sometimes the easiest fix is the one that is most over-looked. I am going to check his air filter today and see what it looks like. I'll let you guys know what I find.
