cam shaft &spring
Has any one put in the new comp cam and springs in. My ford dealer just talked me in to installing it in my 2007 38 hp if any one has one let me know would like true hp and sound clip if you could. I was told it sounds like the old days
SEARCH... its your friend... No seriously there are a huge number of threads on this already.
Now first what is your dealer charging you.. Next is he going to warranty it..and 3rd what cam stage are we talking about. If he said springs it would probably be stage III or IV.
I need to get a dealer that try to talk me into adding mods and not taking them away
I have had allmy work done a dealership warranty i have 3000 km on the engine and 35k into the car warranty is if it breaks due to drive abuse no warranty but i ahve only 9 psi boost these guy have done lots and only one has ford not back running 12 psi booost. with the cam and the new 3000 stall i am installing this thing will fly dyno 502 crank hp at 3500 ft. When it and if blows short block will be fordged and will run in the 600-700 hp range
[IMG]local://upfiles/52448/299A6E6400484773980AF93D8429B5D5.jpg[/IMG]
bradleyb
Nov 27, 2015 07:50 PM
