More Cam Choices !
Old Feb 16, 2007 | 10:08 PM
searay2006's Avatar
searay2006
Default More Cam Choices !
Looks like we have more cam choices now than just COMP.
Crane: stage 1,2 and 3
Crower: stage 1, 2 and 3
Crane stage 3 specs: Lift , in-552 / ex-600 Duration , in-284 / ex-300
These should be a lopie *****
[sm=massbounce.gif]
Old Feb 17, 2007 | 02:24 AM
Norse1974's Avatar
Norse1974
Default RE: More Cam Choices !
Interesting indeed!
Old Feb 17, 2007 | 04:29 PM
saud alzaabi's Avatar
saud alzaabi
I never understand these cam thing like lift and duration.. But one day Im gonna learn that **** and going to choose my own cams...
Old Feb 17, 2007 | 04:59 PM
acstone7's Avatar
acstone7
ya some explanation of that would be nice, im a n00b
Old Feb 17, 2007 | 05:39 PM
sw07gt's Avatar
sw07gt
I would also like to learn about that.
Old Feb 18, 2007 | 12:21 AM
spyder7724's Avatar
spyder7724
just real quick:
lift is how far the cam will open the valve to let air in or out of the cylinder. measured in inches usually. .500 lift just means it lifts the valve a 1/2 inch.
duration is how long it stays open. measured in degrees of crank rotation. 280duration means the valve is open during 280 degrees of the cranks totalrotation of 360 degrees.
higher numbers on both of these are more aggressive cams and usually will increase the rpm range of the engine or change the power curve to peak at a higher rpm.
the rest is too technical for me to explain cause half of it i really don't get. i just know what works for a given rpm range and target hp. i let the cam company set me up with all the specs. they know this stuff much better so i trust them to help with my decision.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
