Check the Engine LIGHT
Old May 17, 2007 | 03:38 PM
Mean Yellow's Avatar
Mean Yellow
Default Check the Engine LIGHT
Ok,, I have installed BBK cold air intake and Corsa X pipe & Corsa axel back on my 06 GT!! I LOVE IT!!!!! Twice now I had to reset my check engine light!! I checked the gascap and it was ok!! I am running 93 octane gas!! What do I need to do next to stop this???? Thank you in advance for your time!!
Old May 17, 2007 | 04:45 PM
Mpaint99's Avatar
Mpaint99
Default RE: Check the Engine LIGHT
Have you bought a tuner yet?
Old May 17, 2007 | 04:49 PM
shooter23's Avatar
shooter23
what code is it reading?? get it scanned and find out what the code is...and then fix it!
you might need a tune...
Old May 17, 2007 | 04:51 PM
Mean Yellow
Not yet!! I am looking at SCT Livewire!! Do you thick this will do??
Old May 17, 2007 | 04:57 PM
Mean Yellow
I reset the light myself!! The dealer told me to take the positive post off the battery for 20 minutes and it will reset itself!! He thought the computer will adjust to the new CAI , first I thought it did but, when I got on it the light came on for the second time!!
Old May 17, 2007 | 08:28 PM
Cobrakev's Avatar
Cobrakev
You need a new tune with a CAI. The computer can not keep up with the added airflow into the engine. Hopfully you are not running rich or lean, but you will need that tune. I think their is only one or two CAI that don't require a new tune. Also check to be sure you didn't disturb the O2 sensors when you changed the pipes over. This will also throw a code. Go to a carparts store and have the code read when the light is on. They will do it for free, and give you the code number.
Kevin
Old May 17, 2007 | 09:13 PM
howarmat's Avatar
howarmat
s197 Junkie
You need a tuner for shutting the O2s off and also the intake.
Old May 17, 2007 | 11:39 PM
modular81's Avatar
modular81
I think the bbk cai is a no tune needed cai and your cel is a result of the corsa x-pipe installed. Any hi flo midpipe other than the stock h-pipe will trigger a cel for the rear o2 sensors. It seems the the only midpipe the rear o2 sensors like without tuning is the stock one.You need to have the rear o2 sensors turned off and your problems will be solved.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
