times
Old Jun 24, 2007 | 01:09 PM
markrey1's Avatar
markrey1
Default times
ok ran the car last night i think it did ok here are my mods 3.73,100shotzex, flows,tune, afe cold airmy best was 8.507 in the eighthard to get the car to stick on street tires i need to get some drag radials what are the best tires for the price
Old Jun 24, 2007 | 01:26 PM
MusiccityGT's Avatar
MusiccityGT
Default RE: times
You definately are reflecting a traction issue with those mods and that time. What was your 60 foot and your trap speed??
Old Jun 24, 2007 | 01:35 PM
markrey1's Avatar
markrey1
Default RE: times
8.507,72.3, 60foot1.715 9.208,77.1, 60foot 2.154 this is my first time ever running on a track
Old Jun 24, 2007 | 02:49 PM
MusiccityGT
Default RE: times
That first 60 foot is great for stock suspension and street tires. Did you spin 2nd bad? You will need to look at some suspension upgrades and some good tires. There are a lot of options and opinions on the d/r's. Kinda depends on the rims you intend to use. Not bad for a first outing!!
Old Jun 24, 2007 | 02:54 PM
markrey1's Avatar
markrey1
Default RE: times
i also lowered the with frpp spings when i was spraying it would not hook until 3rd gear
Old Jun 24, 2007 | 03:14 PM
MusiccityGT
Default RE: times
Look at some good LCA's and an upper link as well as some D/R's for starters. I would expect to see a very low 8 if not breaking the 7's with the 100 shot. That, patience and practice backpeddling when you start to spin.
Old Jun 24, 2007 | 11:51 PM
markrey1's Avatar
markrey1
Default RE: times
thanks for the input i will start looking for the parts i see steeda has a kit for 299.00
Old Jun 25, 2007 | 12:28 PM
moosestang's Avatar
moosestang
Default RE: times
72.3 is your trap speed? 1.7 on street tires? i didn't think that was possible. That trap speed can't be right.
You need some lower control arm relocation brackets since you're lowered.
ORIGINAL: markrey1
Old Jun 25, 2007 | 01:42 PM
markrey1's Avatar
markrey1
Default RE: times
that is right i just look at it agian is that good or bad
time 8.507 trap 72.3 60foot 1.715 reaction .778
Old Jun 25, 2007 | 03:26 PM
Simon1's Avatar
Simon1
Default RE: times
ORIGINAL: markrey1
It doesn't seem right to me either. With a 1.81 60',I pulled an 1/8th at 88.26 @ 8.01. I have simliar mods with a 75 shot, 4.10'sand a built suspension (not completly but almost). I've seen the time machine make errors on slips before, so keep that in mind.
A 1.71 60' on street tires is unheard of. Not saying your making it up, just keep in mind the above info.
You should be able to get what I had in my sig. Make sure your car cools down between runs (half hour or so with your hood propped open out of the sun)and your bottle is warm (a must!). Get LCA's, tokico d-specs (soft in back firm in front), BMR relocates and some drag radials and you should atleast get down in the low-mid 12's.
I have the BFG's and love them. After 6 runs it seems they are still getting through the big tread down to the good stuff so my 60' should get down to the low 1.70's or even a 1.65. I wish. . .
