cat removal question
Old Jun 24, 2007 | 05:18 PM
burnout083's Avatar
burnout083
Default cat removal question
first off, there are no imissions in florida so that doesn't apply.
so i was thinking of taking out the cats and had acouple ofquestions.
are there any gains or losses from this?
will this set off the check engine light?
thanks in advance
Old Jun 24, 2007 | 05:27 PM
wolfey2k's Avatar
wolfey2k
Default RE: cat removal question
Cat removal = gains.
Cat removal = check engine light coming on periodically.
Just keep your tuner on hand so you can reset it when it does.
That's onegoodlookinGT there man!
Old Jun 24, 2007 | 05:28 PM
rravolt's Avatar
rravolt
with removing the cats it will set off the o2 sensors unless u go and get an o2 simulator which is basically just like a chip that u plus ur o2 wires into and it simulates the reading that would of been there if the cats were still there i dont think this part is expensive i believe it is like maybe 2 to 3 hundred and i know it is an easy install cus my friend did it to his 2000 gt and it only took him about an hour
Old Jun 24, 2007 | 05:31 PM
burnout083's Avatar
burnout083
thanks alot guys. i think i might take em off next weekend
Old Jun 24, 2007 | 05:36 PM
rravolt's Avatar
rravolt
netime
Old Jun 24, 2007 | 05:41 PM
howarmat's Avatar
howarmat
s197 Junkie
They are called mil eliminators and cost nowhere near 2-300....you can turn the sensors off with the diablo tuner though so the CEL wont come on again. Its in the manual. Or you can even contact the vendor that did your tunes and they can shut them off for you.
http://www.pmpparts.com/index.php?ma...p;cPath=1_5_48
Old Jun 24, 2007 | 05:45 PM
wolfey2k's Avatar
wolfey2k
ORIGINAL: howarmat
Ahh, that's right! I forgot about that. I don't use that feature so it slipped my mind. Sorry.
Being in Virginia, Fairfax County which is one of the most over regulated commy counties in the world, I have no hope of ever being able to remove my cats for street use. Too bad too because I sure wouldremove those carbon collectingflow clogging expense causing pieces of crap ifI could!
Old Jul 9, 2007 | 12:05 PM
Dorsil's Avatar
Dorsil
why not just leave the Cats on? and be enviromental friendly =)
Old Jul 9, 2007 | 02:40 PM
Norse1974's Avatar
Norse1974
I went with an o-r x pipe that bung holes for my 02 sensors and Ive never had a code thrown!Just recently I had the 02 sensors tunred off for when I run my 110 octane/125shot tune.
Old Jul 11, 2007 | 02:52 PM
okbfd's Avatar
okbfd
Cut them on a Roush, turned off the sensor with SCT, seemed to be a slight gain and sounded great
