Mod help/suggestions
Old Jul 20, 2007 | 08:22 AM
majustin1's Avatar
majustin1
Default Mod help/suggestions
I have an intake/tune and a hurst, but i am looking to add:
4.10s
Aluminum Driveshaft
BMR lca
BMR Panhard
BMR rear sway bar
I am sitting on factory 18s BFG 235/18s. Will i be able to get any traction low end without killin the clutch? Its a DD, but i wanted some help downlow. I plan on getting some 255s when this set runs out but i only got 7k on the stockers. If anyone has any suggestions i take em.
Old Jul 20, 2007 | 09:29 AM
shooter23's Avatar
shooter23
Default RE: Mod help/suggestions
Charge Motion Plates, UDP...also things to think about...
What do you mean traction? If your driving normally, then no problems, if you jump on it...then yes, you could lose traction...but these cars can do that stock...
The suspension will help alot...
Old Jul 20, 2007 | 04:22 PM
majustin1's Avatar
majustin1
Thanks for the reply. Its funny you added plates and pulleys because the basket that i made from brenspeed has all that in it. My parts total including shipping from all the places i had to locate parts from came down to $1800. Without the pulleys and plates i can keep it under 1500 which makes the wallet smile... unless anyone here can back up why plates and pulleys (350) would be worth more than soem of the stuff i mentioned above.
Thanks
Old Jul 20, 2007 | 06:16 PM
s197richie's Avatar
s197richie
I ♥ Acer
get the 4.10s, rear ca's and some sticky tires...
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
firecoyote
Sep 27, 2015 02:37 PM
