Rear end girdle?
Old Aug 1, 2007 | 09:10 PM
Norse1974's Avatar
Norse1974
Default Rear end girdle?
At what point do you need a rear end girdle?Im deffently doing one on mine due to future mods(new motor) putting me at 750-800RWHP(on the bottle).But at what point would a girdle be a good idea?
Old Aug 2, 2007 | 01:20 PM
Norse1974's Avatar
Norse1974
Default RE: Rear end girdle?
WOW!Nobody has an idea of how much?Is there anyone here even using one?
Old Aug 2, 2007 | 02:33 PM
Simon1's Avatar
Simon1
I've got one, it was $199. i've got the FRPP version. I don't know what point it would be a good idea but, why not? It looks better than the stock POS.
Old Aug 2, 2007 | 02:43 PM
howarmat's Avatar
howarmat
s197 Junkie
I have one too and most just have it put on when they do gears, dont know at what HP its needed but I would say you need one
Old Aug 2, 2007 | 03:30 PM
rravolt's Avatar
rravolt
ive also heard good things about the che one with the axle brace
Old Aug 2, 2007 | 03:59 PM
techmanBDsStang's Avatar
techmanBDsStang
I will change it the day I change the fluids. Might as well, and from what I read, it makes it easier to change the fluids, as there is a drain plug at the bottom as well. And I want the FRPP one for the looks as well. I know it will be a little more expensive, but I want that FRPP insginia on it.
Old Aug 2, 2007 | 04:06 PM
mAnYsTyLeS's Avatar
mAnYsTyLeS
LPW sells a very nice one as well.......I think I will be purchasing it with my new gears
http://www.lpwracing.com/p_capcovers.asp
Old Aug 2, 2007 | 05:33 PM
mustangman02232's Avatar
mustangman02232
TA rear girdle, and get the stud kit with it
Old Aug 3, 2007 | 12:45 PM
Norse1974's Avatar
Norse1974
Stud kit?What does that do?
Old Aug 3, 2007 | 07:30 PM
moosestang's Avatar
moosestang
ORIGINAL: Norse1974
I think he means load bolts for the bearing caps, which should allready come with any girdle. Be aware that not all girdles for the ford 8.8 will clear the stock panhard bar. There are even fewer that will clear an aftermarket bar. The ford racing one clears, but you need the one specific for the 05up mustang, part number ending in G2. the lpw girdle also clears.
