driveshaft issues
Old Dec 1, 2007 | 03:24 PM
joshetc's Avatar
joshetc
Default driveshaft issues
I'm in the process of swapping out my stock driveshaft for a spydershaft. I've run into quite a troublesome issue. It seems my driveshaft is suck in the rear pinion flange and I've got no idea how to get it out. All 6 bolts are removed and it is completely unmated from the transmission.. now I just can't get the back to slide out of the pinion flange.
Any ideas? This is driving me crazy and I'm almost out of sunlight..
edit: I have a feeling some loktite came out the holes and has bonded the driveshaft to the pinion flange and as a result of the extremely cold temperatures is just too hard to break the bond. I've got no wheels atm as my car has no driveshaft on it but a friend is bringing me a torch tonight.. so I'll just try that as it weakens the loktite bond, if nobody has any other suggestions.
Old Dec 1, 2007 | 03:43 PM
spyder7724's Avatar
spyder7724
Default RE: driveshaft issues
sorry i don't have any better ideas for you than a BFH
those things are really tight sometimes and just need to be convinced their departure is necessary. after persuading mine a few times with a 5lb Chevy wrench it saw things my way. now when i change them on other cars it's the first thing i do to remove the stock shaft from the CV joint flange.
Old Dec 1, 2007 | 03:49 PM
joshetc's Avatar
joshetc
Sounds like a plan. I'll give it afew whacks and see if that helps...
Old Dec 1, 2007 | 04:03 PM
joshetc's Avatar
joshetc
A few good whacks with a 10lb sledge and it came right off, thanks.
Old Dec 1, 2007 | 05:27 PM
Diabolical!'s Avatar
Diabolical!
I had the same problem. After I had the front and middle of the shaft disconnected, I grabbed the front of the shaft with a slide hammer and after two or three good wacks it came right off.
Old Dec 2, 2007 | 05:39 PM
spyder7724's Avatar
spyder7724
cool pm me or email if you need anything.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
