QUESTION ABOUT X PIPES
Old 12-11-2007, 09:33 AM
Tormentor
Tormentor's Avatar
Default QUESTION ABOUT X PIPES
Do all Xpipes give that raspy sound. Also what ones arent that bad (raspy wise)
Tormentor is offline
Old 12-11-2007, 02:36 PM
Bluestar
Bluestar's Avatar
Default RE: QUESTION ABOUT X PIPES
FRPP ($139.00) FTW
Bluestar is offline
Old 12-11-2007, 02:45 PM
onederful100
onederful100's Avatar
i think all x-pipes will have that raspy, x-pipe sound. you can camouflage it w/ resonators, diff muffler setups, but theres no getting away from the xpipe sound. i really believe the x-pipe sounds better w/ a straight thru muffler. i love my xpipe, love how it sounds, but i know a lot of people dont, its a personal preference. my boomtubes help to keep the sound low and rumbling, but once the rpm's go above 3500, the xpipe starts screaming, in a good way.
onederful100 is offline
Old 12-11-2007, 04:46 PM
Tormentor
Tormentor's Avatar
I have the FRPP stingers on my car. I'm not sure if I want to go with an x or an h pipe, to many options out there.
Old 12-11-2007, 04:54 PM
rshamekh
rshamekh's Avatar
I have the stingers with an o/r H .. and sounds good to me ..
rshamekh is offline
Old 12-11-2007, 05:12 PM
UrS4
UrS4's Avatar
I don't think all X pipes are created equal.
I have a Pypes O/R X pipe and despite its cheap price has good welds at the cross over an the connection is large with a relatively oval opening seen from the inside. I have heard some X pipes might not have as large a connection thus impeeding cross flow which would affect sound.
UrS4 is offline
Old 12-11-2007, 07:12 PM
sweetlou69
sweetlou69's Avatar
seems like most of them are.Ive heard a few decent ones,but i def like the sound off the O/R H def better.
sweetlou69 is offline
Old 12-13-2007, 07:21 AM
Norm Peterson
Norm Peterson's Avatar
A "X" shares the actual flows from the right and left cylinder banks between both mufflers. That generally takes out a lot of the low frequency "rumble" that is traditionally associated with true duals and (to a slightly lesser extent) "H" crossovers. An "H" damps out the peak pressures from each bank a little, but isn't particularly good when it comes to actually sharing/equalizing the flows.
I'd characterize the "X" sound as being more of a snarl once you pick the revs up a bit- smoother and more even, with a higher pitch - and sounding closer to what some folks have done in circle track and road-racing* than what you'll hear at the drag strip if that helps any.
* including Formula 1, if you remember the time when those engines were only turning 9000 rpm or so
Norm
Norm Peterson is offline
Old 12-13-2007, 10:06 AM
Tormentor
Tormentor's Avatar
who makes a good quality stainless x-pipe that wouldn't require cutting my old unit in case I want to go back to stock form in the event that I have to go for an emissions test? I currently don't have them where I live but don't know how long it will be this way.
Old 12-13-2007, 06:33 PM
SpeedRacer9220
SpeedRacer9220's Avatar
I love my Bassani Catted X. Sounds great with my Flowmasters.
SpeedRacer9220 is offline
Quick Reply: QUESTION ABOUT X PIPES
