Problem, please help!
Old Jan 31, 2008 | 07:35 PM
UrS4's Avatar
UrS4
Default RE: Problem, please help!
Okay, so disconnect the DS and rotate 180 degrees and try it again.
I was told by Ron that if your car is lowered less than 1.5" or less you do not need a pinion angle adjustment. I am at stock ride height and Ron told me I shouldn't have to worry about pinion angle change.
I have heard rotate the DS 45, 90, and 180 degrees. Should I start at 180 and keep rotating until it gets better? What do you torque the bolts to? 40 ftlbs?
Old Jan 31, 2008 | 09:27 PM
phatphil's Avatar
phatphil
I'd rotate 180 to start withand as far as torque on the bolts it seems 36 ftlbs come to my mind but don't take my word for it. I could be confusing that with something else. I hope you resolve your problem, the noise you describe probably can't be heard unless windows are rowed up and radio is off. There were quite a few threads on this a year or so ago. Good luck and let me know the outcome.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
