Timing and nitrous
Old Mar 5, 2008 | 06:58 AM
06_gt's Avatar
06_gt
Default Timing and nitrous
I hear that you dont need to adjust your timing for a 75shot of nitrous. I had my car dyno tuned with an o/r x, race axel back, cold air intake, and cams. I would have thought my timing would have been adjusted. I pluged in my sct tuner and it read "0-2000 spark 0 degrees" "2000-4000 spark 0 degrees" and "4000-8000 spark 0 degrees". Is this my timing or what? Im wondering because i have had the car tuned and i want to put this nitrous on but i dont want to hurt my motor. Thanks for any help!!
Old Mar 5, 2008 | 12:09 PM
cfr865's Avatar
cfr865
Default RE: Timing and nitrous
Which octane tune are you running ? I was running the 93 oct. tune from Brenspeed for everyday use,Brent said to run the 91 oct. tune with the 75 shot, this is what I did without a problem.The 91 tunedoes have less timing. I have since went FI.
Old Mar 5, 2008 | 12:10 PM
cfr865's Avatar
cfr865
I forgot to add Brent said to use 93 oct. fuel even though I was using the 91 oct. tune.
Old Mar 5, 2008 | 12:26 PM
grampa_stang's Avatar
grampa_stang
The "0-2000", "2000-4000", and "4000-8000" are the RPM ranges.
The "0" is the starting point of your adjustments to either add or pull
timing from the current setting.
carid
Jul 8, 2016 09:55 AM
mungodrums
Oct 7, 2015 04:01 AM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
