Driveshaft
Old Apr 3, 2008 | 09:12 AM
BUGT's Avatar
BUGT
Default Driveshaft
Well I bought an aluminum driveshaft off of my friends '06 saleen (only has 3 or 4k on it and never raced with). I was just wondering, since I really don't know much about drivetrain, if there are any problems when installing one, or once its installed? I've read on the internet about pinion angles but Im not sure how much that will affect it.
Sorry for being dumb haha but this is what the forums for right?
Old Apr 3, 2008 | 09:14 AM
06VistaBlueGT's Avatar
06VistaBlueGT
Default RE: Driveshaft
Technically you should adjust your pinion angle after installing it. I installed mine a few weeks ago and haven't touched the pinion angle. I have no noise or vibrations so far.
Old Apr 3, 2008 | 09:31 AM
GidyupGo's Avatar
GidyupGo
You can look at the procedure on the sticky Tacobill has about his DS replacement. Even has pics. https://mustangforums.com/m_3627551/...tm.htm#3627551
Old Apr 5, 2008 | 06:38 PM
wadman's Avatar
wadman
I will be surprised if you dont have issues with your drive shaft. I can tell you that I have had a aluminum and a chromoly d/s and both had vibration and a cabin noise. Yes I adjusted the pinion angle. When I put my stock shaft back in all the problems went away. Every new mustang ive been in with a aftermarket d/s has had some sort of issue. I wish everyone on these forums would be honest about the problems they have with different parts so people wont waste their money.
Old Apr 5, 2008 | 08:17 PM
Blue Meanie's Avatar
Blue Meanie
I don't have any problems. I think the pinion angle only comes into play if you car is lowered. If you're just changing the driveshaft from the stock one how would that affect your pinion angle at all?
Old Apr 5, 2008 | 08:18 PM
Riptide's Avatar
Riptide
Which products have you had or seen problems with wadman?
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
FivePointToTheOh
Sep 14, 2015 03:35 PM
