4.6L Engine Specs.
Old Apr 9, 2008 | 09:59 AM
vf96's Avatar
vf96
Default 4.6L Engine Specs.
Anyone out there have a link for our 4.6L engine specs? I want to start installing braided hose lines. but I need the information about hose line sizes
and fitting sizes. Any help would be very helpfull!!!!!!!!!!!
[IMG]local://upfiles/92103/6B1D2703501D47D7962121DFD20A42CE.jpg[/IMG]
Old Apr 17, 2008 | 11:37 PM
Tjeppelin's Avatar
Tjeppelin
Default RE: 4.6L Engine Specs.
have you tried google you should be able to get spec sheets.
Old Apr 17, 2008 | 11:47 PM
Jokeurmnd's Avatar
Jokeurmnd
VF96 if you do end up getting the size for the hoses would you be able to pass it on because I would love to get braided hoses as well
Old Apr 18, 2008 | 08:17 AM
vf96's Avatar
vf96
Iv'e googled my butt off........no results at all. ford dealer no results looks like I have to pull hoses and measure inside & outside diam.
called Earl's they said they will send a catalogue and start from there. jokeurmnd.......keep checking back. I WILL post when I find what we need.
Old Apr 18, 2008 | 06:20 PM
drbobvs's Avatar
drbobvs
scramblr
titleAndStar(796,0,0,false,",")
[align=center][/align]
Status: offline
I've posted this a bunch of times, so it's just copy and paste now. As mentioned though, Summit's prices are pretty good. ---
First go here, http://www.powerflowracing.com/spectre-catalog.asp and select "Plumbing" then "fuel hose". Determine all the part numbers needed and then to Autozone web site. You can probably walk into an Autozone and pick up this whole kit and the fittings will be red and blue. I only wanted blue fittings so I bought the hoses and fittings seperately.
Or you an go to each link below which are the parts I bought seperately.
5/16" line: http://www.powerflowracing.com/spect...il.asp?PD=752. It's 48" long and you cut it to the size you need and slip the other clamp on. Need one of these.
3/8" line: http://www.powerflowracing.com/spect...il.asp?PD=759. It's 72" long and you cut it to size also. Buy an extra set of clamps.
5/8" line: http://www.powerflowracing.com/spect...il.asp?PD=827. This one is 48" long and you cut it to size also. Need one of these as well.
The radiator overflow, passenger side PCV, fuel vaccum, and brake vaccum are 3/8", the fuel rail one is 5/16", and the big PCV on the driver's side is 5/8".
Then you can go here and pick out the part numbers of the clamps that you want if you don't pick up a kit. http://www.powerflowracing.com/spect...=15&PSG=53
Hope this helps. Oh yeah, you'll neel either a hacksaw (wrap that section of hose with tape first) or a Dremel to cut through the hoses. I used a Dremel and it cut right through. Let me know if you have questions.
< Message edited by scramblr -- 5/14/2007 6:25:50 PM >
_____________________________
12.8 @ 105
C&L/XCAL2, UDPs, CMDPs, Kooks, Stingers, Spyder DS, Centerforce DF, Fidanza alum f/w, MGW Shifter, Ultralite Springs, Prothane Mounts, BMR - Adj. Panhard Bar, LCAs, LCA Relo Brackets, Adj. UCA, Rear Sway, Sway Delete/Rad Support, D-Specs [align=right]
(in reply to MELLOWYELLOW06) [/align]
Report | Post #: 7
RE: Braided hose kit? Covers? - 5/14/2007 6:41:42 PM
Galactic
Apr 29, 2019 02:56 PM
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
