lifter problems!!!
Old Jun 23, 2008 | 11:49 AM
super05mustangGT's Avatar
super05mustangGT
Default lifter problems!!!
I have a2005 GT and i have aftermarket cams. I have replace my lifter once already. The lifter are making noise again. I want to replace them my self this time. What will Ineed other than lifters and rockers. Is thier any thing else that needs to be replaced as well?
Thanksfor your help
Old Jun 23, 2008 | 02:01 PM
Mpaint99's Avatar
Mpaint99
Default RE: lifter problems!!!
You will need to replace your springs and retainers. If you didnt when you changed cams.Check you lifters they might not be bad. It might be your valves are traveling wrong since cam change.
Old Jun 23, 2008 | 02:08 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: super05mustangGT
Thanksfor your help
Umm..our cars are OHC (overhead cams), therefore no pushrods, therefore no lifters
Do you mean the cam followers or valve retainers? Depending on the lift/duration of the cam you may need different valves or just get different springs as stated by Mpaint99.
Edit: Ford does a really bang-up job of confusing people. I just took a look at a head parts explosion. What OEM refers to as a lifter is actually a follower. [>:]Ask most mechanics and look at the TSB released by ford for SERVICE, they're refered to as a cam follower, not lifter.
Old Jun 23, 2008 | 04:05 PM
Green08BulliTT's Avatar
Green08BulliTT
http://iihs.net/fsm/?dir=159&viewfile=Engine.pdf look at page 303-01 b3 there is a part called Hydraulic lash adjuster. there is a possabilty that's whats making your noise. idk if in the new heads they self adj but in other cars they dont. with more agressive cams they could bleed down causing a light tickin noise.
ps http://iihs.net/fsm/?dir=146&viewfile=Engine.pdfis a good place to start looking at what might cause the noise
Old Jul 16, 2008 | 07:50 AM
chadlet's Avatar
chadlet
That is a very handy website. How did you find it?
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
