2005 GT Spark Plug Install 48 K on Car
Old Jan 2, 2009 | 08:45 AM
Slayer7391's Avatar
Slayer7391
Is it true that the 2008 dont have these issues.
Old Jan 2, 2009 | 11:16 AM
samus720's Avatar
samus720
I have heard that before. I believe it's because Ford became aware of the problem and began putting anti-seize from the factory on the spark plugs, thereby allowing them to come out easier than the previous models.
Old Jan 2, 2009 | 05:04 PM
SCCAGT's Avatar
SCCAGT
Ford made a running change with these heads. Sometime in Feb 08 the design was changed and the plugs are different. Anti sieze was not the cure.
Old Jan 2, 2009 | 05:06 PM
samus720's Avatar
samus720
I see... Thanks for the correction. Did they go to a one piece design, or is it still two piece?
Old Jan 2, 2009 | 10:42 PM
Jersey Stang's Avatar
Jersey Stang
If anyone needs the spark plug extrator tool, send me a PM. I found a place that sold it for only $75. I think Snap-on is asking for over $100. I ended up never using it. If you need it, let me know!
Old Jan 3, 2009 | 09:43 AM
jminnich21's Avatar
jminnich21
I found some that's $59 to $65 to the door from 2 diff places it may bee cheaper for you I'm in Orlando. Here's the links http://www.unbeatablesale.com/egle04...ci_sku=EGLE045
http://www.toolrage.com/prodView.asp?sku=ATD-5402
Is there anyone in Orlando area that has one that may let me borrow it should I need it? I only have about 15.000 on my 07 so I may be lucky.
Old Jan 3, 2009 | 01:07 PM
SCCAGT's Avatar
SCCAGT
The new plugs are one piece, but look more like a regular spark plug. They dont have the long smooth piece that breaks off.
Old Jan 4, 2009 | 10:35 AM
charliebrown266's Avatar
charliebrown266
Is there anyway to tell if mine were different? my car was built feb 08
Old Jan 4, 2009 | 08:45 PM
white07's Avatar
white07
I read these and it makes me not want to change mine out but I know the longer I put it off the harder they will to take out. Im only at 23K right now. My buddy works at snap-on im gonna see what he can do for me.
Old Jan 4, 2009 | 09:08 PM
NJ3's Avatar
NJ3
If the number on the label on the drivers side cam cover ends in AB you have the new style heads and plugs.
