RAM AIR
Old Feb 5, 2009 | 12:33 PM
FireStang92's Avatar
FireStang92
Default RAM AIR
I am looking at installing a RAM AIR system into my 08 GT. What are some of the pro's and con's and what other complications may arise with this? I would appreciate all feedback on this.
Old Feb 5, 2009 | 12:47 PM
Nuke's Avatar
Nuke
Can you post a link so I can see the specs?
Hopefully other forum members will correct me if I'm wrong but here's my take:
The stock throttle body can pass move a certain amount of air. The stock intake is known to be somewhat restrictive and a CAI will improve on that. However, the engine cannot benefit sufficiently from the increased air flow on it's own so a custom tune is required. Any CAI that is worth it's weight requires a tune (including some that claim no tune required).
A ramair system, IMO, will not perform any better than a CAI and will still require a tune to be able to utilize the air flow for the best performance. Not knowing how the ramair system is designed and IF it's made for our 4.6L engines, I'd be concerned that it would not be compatible with the MAF sensor unless it came with a tune.
Old Feb 5, 2009 | 12:52 PM
FireStang92
It's a RAM AIR from Cervini: https://www.cervinis.com/product.asp...1&id=1208#1181 part#1181 hood and ram air. It says no tuner needed.
Old Feb 5, 2009 | 06:28 PM
shanec's Avatar
shanec
All that Cervini kit does is scoop fresh air through the hood and route it directly to the factory air box. I think it does virtually nothing performance-wise.
Old Feb 5, 2009 | 07:54 PM
GT John's Avatar
GT John
Here ya go.
Wouldnt have it any other way.
http://www.musclemustangfastfords.co...kit/index.html
Old Feb 5, 2009 | 08:17 PM
acascianelli's Avatar
acascianelli
+1
I don't think you're going to notice any tangible difference in performance with a "ram air" setup over a conventional intake setup on the S197.
Old Feb 5, 2009 | 08:21 PM
Hootna's Avatar
Hootna
Dont think Ramair happens until higher speeds.
http://www.agentfortyseven.com/S197/ramair.html
This is what I would do if I was on the track only.
Old Feb 5, 2009 | 08:25 PM
acascianelli
I actually like the way that looks, you might also be able to modify Agent 47's brake cooling kit to feed cool air to the airbox.
Old Feb 6, 2009 | 05:17 AM
Bails's Avatar
Bails
I'm not 100% on this so feel free to correct me but this what Cervini's told me when I got my ram air setup from them. Basically you'll have a small power increase from about 30-70mph, after 70mph air just goes right over the hood. But then again I have #1171 hood which starts farther back, the closer to the front of the hood the more effective the ram air will be.
Honestly though I think it's more of just a looks thing because the power gains are marginal and not very noticeable.
Old Feb 6, 2009 | 08:53 AM
FireStang92
Thanks guys, looks like I will be going the CAI and Tuner route.
