PA alternators
Anyone running one of these??
http://www.americanmuscle.com/130amp...or-0509gt.html
I have been reading online and pretty sure I have a bad alternator ( despite Ford telling me it's fine ) so I am just gonna replace it with one of these.
I keep getting the danged check charging system code on the tach everytime I connect my SCTx3 tuner...
As long as the check charging code goes away, it's normal to get that code when you connect your tuner. There's a few other codes that pop up also, but I can't recall what they are. But they're temporary. Ignore them unless they're still there after you disconnect the tuner.
FYI - I know 2 people who have used the PA alternator and it took a dump within a month and both of them went back to new stock alternators...
My stock alternator took a dump at about 20K miles and then I replaced it with another stocker and ran fine. (with 700 to the tires BTW)
I am about to make over a 1000 to the wheels on the stock alternator.
dang it.. if it's not the alternator that's making my car die every few weeks or so what else could it be??
My only guess is that somehow I am trigger the engine relay disable feature on my alarm system and it disables the car from being started.. that's about it.
ps.
1000 hp? DAMN! lol..
ps.
I'm not saying your alternator isn't bad. Hell, mine went out and I know a dozen guys who have had to replace there's. I'm just saying the stocker seems to be a better and more reliable unit than the PA's IMO.
What makes you sure you have a bad alternator?
ps.
ps.
I may try out Bama tunes Race tune and see if that changes anything..
(O_o)
new battery as well.. replaced it last week.. before the car died again a few days ago.
I'll try it when I am putting some exterior mods back on my car this week ( louvers, bullitt grill etc. )
I really hope whatever it is that's plaguing it either surfaces and it's an easy fix or it goes away.
(O.O) ??
(O.O) ??
