Anti-squat/relocation brackets
Old Apr 3, 2009 | 03:35 PM
BlackS197Stang's Avatar
BlackS197Stang
Default Anti-squat/relocation brackets
Is an anti-squat bracket the same as a relocation bracket, but without the multiple holes? What might you typically gain in 60ft. times with stock tires, nonadjustable LCA's and antisquat/relocation brackets? Will adjustable lowers change the pinion angle just like the upper?
Old Apr 3, 2009 | 03:59 PM
owero01's Avatar
owero01
Yes, they are the same as relos. The gain is dependent on you skills. It will help the rear wheels plant better. Adjustable lowers can be used to change the pinion angle, but it is a lot easier with the upper because you only have one adjustment to make. With lowers, you have to adjust both and getting them to be the same can be a PITA.
Old Apr 7, 2009 | 06:14 AM
GT John's Avatar
GT John
This should answer any questions you may have.
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
Old Apr 8, 2009 | 07:28 AM
one.wicked.stang's Avatar
one.wicked.stang
yes, that guide is what helped me decide on the rear end pieces I installed.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Oct 7, 2015 07:02 PM
Explosive
Oct 2, 2015 07:45 AM
