Acceleration problem
Old May 25, 2009 | 11:10 PM
TornThorn's Avatar
TornThorn
Default Acceleration problem
When my 06 GT automatice is in the 40mph range and I am coasting for a bit then try to accelerate i hear loud rumbling under my seat and dont accelerate! The only way I get going again is if I WOT it. It literally takes me more then 10 seconds to go from 40mph to 50mph even if I push the pedal 3/4 to the floor.
The closer I get to operating temp the worse it gets.
Cleaned the MAF, TB, and reset the adaptive learning.
Tried 4 different tunes and non have solved this problem.
Anyone have this problem?
Old May 26, 2009 | 08:37 AM
ski's Avatar
ski
Did you reset the adaptive learning by disconnecting the battery for 30 minutes?
Also, see if recalibrating the gas pedal/TB helps:
-Turn the ignition to ON so the dashboard lights come on and the chime sounds(Do not start the engine).
-After the chime stops, smoothly depress the gas pedal to the floor while counting 1001-1002-1003.
-Smoothly release the gas pedal doing the same count.
-After the gas pedal is fully released, wait 6 seconds, then turn the ignition to OFF.
-Wait 6 more seconds, and repeat the procedure 2 more times.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
zanemoseley
Sep 6, 2015 12:58 PM
