Whine
Old Aug 10, 2009 | 05:33 PM
scoots's Avatar
scoots
Default Whine
I have a 2005 GT with 94,000 miles on it. The car has developed a whining sound, and I am having a tough time nailing down where it is coming from. You can hear it when giving light throttle, but as soon as you let off it stops completely. Also it gets louder as speed increases from unable to hear at 25 mph to very noticeable at 75 mph. To me it does not seem like gear whine, but I could be wrong. Could it be a wheel bearing or drive shaft related? Any input would be appreciated.
Thanks,
Scott
Old Aug 10, 2009 | 06:50 PM
Stone629's Avatar
Stone629
First guess of course is gear whine, but you say it doesn't sound like that. Its not low on power steering fluid is it?
Old Aug 10, 2009 | 09:48 PM
scoots's Avatar
scoots
No power steering fluid is good. You can really notice at very light throttle. For example driving on the highway with the cruise control on.
Old Aug 10, 2009 | 09:57 PM
Mr. Ugly's Avatar
Mr. Ugly
Alternator bearing can whine when it starts going bad.
Can you tell approximately where the noise is coming from?
Old Aug 10, 2009 | 10:07 PM
Stone629's Avatar
Stone629
It still sounds like gear whine to me. If you can make it sing by applying throttle, and make it stop by letting off, that's definitely what it sounds like.
If it doesn't make any whining noises while you rev it sitting still, that eliminates anything under the hood. That leaves the transmission or rear end. It could very easily be a bearing or just about anything, man. You're just going to have to keep narrowing it down until you get it figured out.
Old Aug 11, 2009 | 01:52 PM
brunobluto's Avatar
brunobluto
The rear axle could be low of oil. That would cause it to whine.
Old Aug 11, 2009 | 03:00 PM
scoots's Avatar
scoots
I took another listen and it definitely sounds like it is coming from the rear end. I had some gear whine while still under warrenty sounded different that this. I t could be heard on accel and deccel in a 35 to 50 mph range.
Old Aug 11, 2009 | 03:01 PM
scoots's Avatar
scoots
Are you talking about the diff?
Old Aug 12, 2009 | 02:09 PM
brunobluto's Avatar
brunobluto
Yes. Might be worth checking especially if you have noticed oily residue on your back wheels or pinion seal and flange.
Old Aug 13, 2009 | 11:28 AM
bynumj's Avatar
bynumj
I took another listen and it definitely sounds like it is coming from the rear end...
Your wife isn't in the back seat is she?
