COMP CAMS THUMPER CAMS
Does anyone know of a good shop in the Houston area for installing the Comp Cams Thumper Cams? Also, does anyone know an estimated price for the install? Might possibly consider installing myself if I could find a good write up on the install. This car is my daily driver so I would feel a little more comfortable having a shop do the install unless it is really easy. I will probably have PSI Motorsports in Webster do the 4.10 gears but not sure if they do the cams. E-mailed them to ask but never got a response.
hopefully someone with first hand experience with a
local shop there, can make a recommendation for
you. this shop looks like they are qualified, but only
you can say for sure after calling them and asking
for yourself.
http://www.houstonperformance.com/
install $ for the cams and phaser limiters (or lockouts),
could be anywhere from $500 - $800.
i would not say it is an easy job. if it's a daily driver, you
may just want to have a shop do it and then dyno tune
it while it's there.
for yourself.
call pat at PSI. He has done all the work to my car and is very good at what he does. He is installing my procharger on monday too. He will get back with you, but he is busy as hell trying to answer phones as well as get in the grease.
Just call him up and tell him that Monte sent you over there.
Comp makes a Thumper cam for the modular Fords? Never heard of that. If true they are an agressive cam and you will need gears, like 4.10's and more supporting mods. 227*/241* is the smallest I have seen for a Thumper. What specs are you looking at for your car.
Trick Flow makes a nice grind for modulars, 226*/230* for $449. and with springs for $599. nice price.
You have a 3V motor don't you? Different cams than I am familiar with, still would like to see where Thumper cams are available and the specs though.
http://www.compcams.com/3valve/
hi! i dont know very well the houston area, but i had this cams on mi car, almost 6 monts ago, is a 05 gt manual whit shorty headers, off road x pipe, flow master series 44 mufflers, S&B air filter, hurst short throw shifter, and, the most, most important, the custom tunning from brenspeed. DONT forget to make the tunning, cause the check engine light will appear, and some backfires too! the cams were installed by my mechanic in weslaco, tx, wich is a guy that works in a ford dealer, he didnt got troubble to install it, hiven with the phasers. i think i got more work to replace the valve springs! so you can check arround w a mechanic in a ford dealer, cause they are experience w this cars, (he did the work at is home, so wasnt expensive)the result: you can feel a little more power, but most this cams are for the sound, and believe me, its incredible! a really muscle car!! let me know the results! thanks
