BBK throttle body voltage help needed!
#21
This BBK TB seems to be an often argued topic. I have heard good and bad things about it. I only know one person with one and he has some pretty bad problems with it, he said he is going to install the factory TB and see what happens.
#23
I'm taking your side Raredesign. I'm very happy with my BBK tb. I did everything that the instructions said and ran into no pcm problems. The instructions said not to worry about checking voltage unless a code is flashed. That was last year and still no problems. And comparing any mods with fi to any that are with a na motor is like comparing apples to oranges.
#25
Wonder what else they dont worry about unless there is a problem
(customers are the problem finders in that case)....
"Dont check the gear mesh on that ring/pinion change unless
there is a problem with noise..."
"Dont check the oil filter for leaks after replacing it unless
there is an oil puddle under your car"...
"Put the fuel line/filter shield back on and drive around.
If you smell gas, check for leaks. If it is
hot, check for fuel fire."
Dont worry, be happy (and broker)...
#26
I just wanted to let everyone know how things have been working out. I have not had any trouble with the TB thus far, and now have a CAI and bama tune. I am planning on putting in some FRPP hot rod cams soon...hopefully.
#27
@raredesign i want to steal your bumper it looks sweet on your car with that hood scoop, nice looking ride. I just had ***** thumpr cams installed on my mustang and boy does it sound awesome so take a look at those if you havn't. ill attach a video link.
http://www.youtube.com/watch?v=rcAU-qwozUs
#28
hey rare, what did you do man I recently installed a twin 62 on my 06. It's been nothing but trouble. No matter how much adjusting I do my car idles at 1000 rpm. It also seems to be getting stuck. for example, at 40 mph in fourth gear, my car rides at a constant 2000 rpm. I'm sucking gas, and it's not good. HELP PLEASE
