2010 Mustang GT vibration at low RPM
Old 07-05-2010, 09:22 AM
2010stang
2010stang's Avatar
Default 2010 Mustang GT vibration at low RPM
I have a 2010 V8 with Automatic tranny and ever since I bought it have had a vibration noise (it doesn't shake the car) coming from either the engine area or under the car when initially accelerating. If I push down harder on the pedal it goes away. Kind of reminds me of a vibration I had years ago when the converter shield was loose. Any ideas? Thanks.
2010stang is offline
Old 07-06-2010, 12:23 AM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
I just had gears, cams , long tubes, and a catted x installed.
I had a vibration on the passenger side... they shaved a bolt for me.
Now i am getting it in the middle of the dash area.
Shop said he thought it might be the headers being close to the heat shields, that it was not bad and I just had to deal with it.
Now it gets BAD.
Especially when I am at my coasting idle RPM (1k).
I am trying to see what it may be too.
Temp and RMP seem to make it worse.
It was not bad but now I GOTTA get it fixed.
Sucks the shop is a couple of hours away and I can't go back till at least the end of the month. I just got back TODAY and it started getting bad when I got home.
I can't friggin stand this.
Since you are stock I cannot fathom what it might be.
I'd take it to the dealership if I were you.
Blacksmoke is offline
Old 07-06-2010, 12:49 AM
muzzy
muzzy's Avatar
Check your u-joints. Sounds like one is going bad...
Thanx-Muzzy 04 S281SC Convertible #355
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Ported and Polished SC by PSE
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
Chicane ss braded IC lines
Carbon fiber dash kit and shift ****
1 bottle of water wetter (haha)
muzzy is offline
Old 07-06-2010, 04:56 AM
jwth2005
jwth2005's Avatar
Being a 2010 the first thing i would have hone is take it to the dealer for warranty.
jwth2005 is offline
Old 07-06-2010, 04:51 PM
2010stang
2010stang's Avatar
I plan on taking it in, but just wanted to see if others have the same issue. Thanks.
Old 07-21-2010, 11:32 PM
HOTRODD77
HOTRODD77's Avatar
Did you ever get this resolved? I am having the EXACT same issue. This was made with a digital camera so quite a bit of background noise, but right around 25 seconds you can hear what I am talking about for several seconds.
Link came out weird, but just click on the pic and you will get the video.
HOTRODD77 is offline
Old 07-22-2010, 07:09 AM
2010stang
2010stang's Avatar
No I haven't yet because it was just in the shop a few days before I posted, so I am waiting for the next oil change. But that is the same sound I have.
Old 07-22-2010, 08:11 AM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Is that sound coming from the engine area or the dash?
That sounds alot like mine but mine came only after installing longtubes and I had SLP loudmouths. After putting stock mufflers back on it ALMOST took care of all the sound. Now it stops when my engine warms up. This is a video after the stock muffers where put back on but the vibration is there at start and before the engine gets warm.
Almost like mine is resonance or something but was almost the sound if not THE same sound...
Here' a video of mine. Happens at 1k-1.2k RPMS
Old 07-23-2010, 07:11 AM
HOTRODD77
HOTRODD77's Avatar
Thats weird, mine stays all day long, actually off to the dealer for the secon time now. I'll update later.
Old 07-23-2010, 04:24 PM
HOTRODD77
HOTRODD77's Avatar
Went to the dealer today. Found a service guy that was willing to try to find what is causing this noise. Told me he heard it clear as day, but was unable to find what was causing it. Told me to bring it back on Wednesday and he would do it again, assured me that he would find it. So, till next Wednesday! I have another thread about this on another forum if you want to read it:
http://www.allfordmustangs.com/forum...1k-2k-rpm.html
I'm assuming it's okay to include this link, right?
Quick Reply: 2010 Mustang GT vibration at low RPM
